Hi All,
My "New to Me" Lunar MH was fitted with a shiney brand new battery when I picked it up, but it seems that an under powered unit was fitted, so I need to up grade.
Currently under the hood I have a BOSCH S4 008, which is a good battery, but the Lunar is on a Ducato with a 2.3 lump so need a higher cranking amp, so I'm up grading to an 019 type (as recommended) with a higher CCA THIS ONE.
Now that leaves me with a spare BOSCH S4 008, and unfortunately it will not fit in the fitted Hab battery box under the drivers seat.
So if I find a suitable spot under a bench seat at the rear, and link in parralel, does it matter that its a different battery to the one currently under the drivers seat? THIS ONE I'm also considerring upgrading/replacing the hab battery under the drivers seat because it does not seem to hold a charge.
For info, I did intend to add one or two extra batteries for off grid use, and do intend to add solar but probably not this year, I just hadn't planned on sticking an extra 50kg at the tail end of the van, I would have preferred the hab batteries to stay in the intended location under the driver and passenger seat.
So back to my main question, as long as they are all just wet batteries, does it matter about anything else?
Thanks in advance
Siblo
Thanks in advance
Siblo
