Magnetic bathroom door
lostevens
Harmony 736 2019
We have a 2019 Burstner 736. Just wondering if anyone can offer some advice regarding how to fix the magnetic door locks which have basically stopped working on the door to the toilet? I’ve tried some washers under the locks to bring the contacts closer but still not successful unfortunately. It appears the magnetic system has failed!! Apart from fitting a strap system (which I don’t really want to do), is there anything else that might work? Many thanks
I purchased these on Ebay and fitted one inside the lock socket. Magnets 25x8x2 mm N52 grade neodymium block small thin rectangle magnet
According to Southdowns Motorhomes service department, this is a regular problem. It happened on our door too (2019 IXEO i720) after only 3 months. Has been replaced now under warranty. (Was due for warranty work in March 2020 but pushed back due to Covid and was carried out in October)
Lock has failed again so going to follow Driventemple advice and try the magnets from eBay.
The magnets from eBay worked a treat. Bought 4 for £3.59. Only used 1...
Thanks for the tip Driventemple (y)(y)
We also have a 2019 Burstner Iexo 736. Found if the door is fractionally out of line the magnetic catch fails to work. Eased where it is mounted by about 2 mm works fine now. When the door is shut if you try to lift the door or pull it tighter and the lock works that is the problem. If I can ask you a question, how long does it take your batteries to come. Up to 100% from say 85% mine will be on charge for anything up to a week and not get there. But if I pull the big fuse by the battery wait a minute or so put it back. In it reads 100% ?
2019 Burstner too. I had to slightly lower the receiver in the frame as the lock would not always pop out. Depended on the way the van was parked up but all ok now and works.
We have just had the same problem on our Lyseo 744- I bought a new latch mechanism from Southdown-just out of warranty. I have tried to remove the old one -taken out the handle spindle and the 2 screws on the door edge but it is still tight at the top— is there anything else securing the magnetic catch or do I just need to force it?
Can it be re magnetised?
That is what I was thinking could do it with a strong magnet or possibly wrap a coil of wire around it and pass a small low voltage current through it.
Well I have followed the earlier posts and put in 2 pairs of washers behind the receiver, this has improved the pull. However the door is fractionally too low and lifting the door up while closing, it slides up on the hinges seems to work, though not ideal. The replacement lock does seem to have a stronger pull, I’d still like to get the old one out, though, to at least shave a bit off the tongue to avoid lifting the door, so ideas appreciated.
Thanks for the advice here as we are suffering the same problem. Dealer has checked alignment and even swapped lock with another MH but problem remains. It appears that the faceplate is being magnetised and the magnet then doesn’t pop out into the receiver. After each visit to dealer the latch works for one night and then gives up. I found a workaround by removing the faceplate and then the latch works perfectly even if it doesn’t look right in the door. Thought about getting someone to make us a non-ferrous faceplate but have ordered some magnets off ebay to try first.
An update: unfortunately the ebay magnets didn’t solve the problem. After much head scratching today it appears that the two screws holding the faceplate are moving the lock out of alignment if tightened up normally. Leaving these screws slightly loose appears to let the latch work but naturally this needs road testing.
Sadly this reminds me of that saying “if at first you don’t succeed, do what your wife tells you” …
Can you realign the door by spacers in the hinges or, in my case, adjusting the vertical door strengthener in the door? The magnet is not very strong and if the lock is out of alignment it will restrict it's effectiveness.
Good Luck!
Same has happened to our Burstner 590… have just ordered a magnet so will try that first
