Light Out error?.
PeteH
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
2009, Rapido On 3L V6 Auto, Sprinter Base. I have a "tail light" error on the dash comes up when I switch the side (and head) lights on. All the lamps check out as working, but the error light remains. I have consulted several Mercedes online "forums". And suggestions range from mismatched lamps, to wiring faults.
So far I have removed and replaced the lamp (standard twin filament 21/5 Pilot and Brake) despite the fact the O/E lamp was not actually faulty. I still have this issue.
It is annoying rather than anything else, as I know I have a full working light set from physically examining the M-H when lit. and I can switch the error off on the steering wheel by cancellation, (it returns next time I fire up).
Any one come across this before?. I suspect it MAY be an earth issue, but finding and cleaning "earthing" points is a long and tedious job. So before I go that route I wondered if anyone had had the issue and a solution.?
Pete
I think this would be my starting point,,, along rear end of chasis N/S should be some earthing points. hope you find the solution.
I have the issue on my Mercedes Rapido, I get a tail light warning and a side marker light warning, although the lights are OK. My solution, such as it is , is to ignore it.
Have you checked your brake lights? Mine did this with an intermittent brake light bulb fault. Replaced brake light bulb. This seems to have fixed it.
Re-Check, this am, shows failed Number plate light Fitting. (Bad Earth). All fed from LH lighting!. I am certain it had been On when I last looked, But????. Repaired the fitting and now OK.
Whilst on this I found 3 of 5 High level brake lights out (tiny little bulbs) When I tried the replace them they broke in the fitting. Have bye passed the Existing lights, with 2 strips of LED`s. Works a treat!.
Thanks guys for input.(y)(y)
