A question for those who understand leisure battery systems better than I do.
Following a minor water leak discovered a few weeks ago, I have been running a small 23w dehumidifier from my inverter overnight. Up until yesterday all was running fine. The batteries are connected to a 100w solar panel.
However when I opened the van this morning, the inverter was not powered up. When I checked the battery status on the control panel, it was showing 11.5 v. the dehumidifier was the only thing running so I assume that was the source of the drain, however it has been fine up to now.
I took the van for a 30 mile drive which upped the voltage to 12.2v & its now plugged into in the EHU which has taken the voltage to 12.5 v.
I have two batteries in parallel one is a Varta 85AH and the other is the original Adria fitted battery which I can’t see any markings showing the AH but assume is @ 60 or 70AH. Also assume the batteries are 4 ½ years old.
So, my question is, how do I know if the batteries need replacing other than waiting to see if they discharge again?
