I decided a double din radio upgrade would be a good idea so fitted the unit mentioned above.
I chose the unit because I wanted HDMI Input, good sound quality, DAB radio and a touch screen.
I have wired the radio up to the leisure battery via a switch on the ACC +Ve line with the permanent +Ve going direct to the leisure battery via a fuse.
I am still going to add rear speakers.
Pros
The sound quality is slightly better than the Blaupunkt it replaced.
Bigger better display is easier to navigate
Led display can be set to match the dash
HDMI is great with my fire stick connected, which also gives wireless screen mirroring from my phone
Plays DVDs, USBs etc
Spotify connection app
2 phones can connect at same time
Phone battery power display
HML connectivity
Software updatable via USB
Cons
No 30 minute power off option
No option to operate with ignition off (if wired as usual to cab battery)
DAB text not as good as some
Difficult to set up
