Isotherm 115 Fridge and Majestic TV’s
Pilote Galaxy 270
Afternoon.
Im about to press the button on these two items. Does the fridge auto switch between detected voltages or will I need a magic box? And the TV, is it “ smart “ enough for 9 and 15 year olds?
Thanks on advance
Steve
If you have an ses fridge set to auto, it will prioritise in the following order first 240 volts if on hook up, if not it will run on gas. When engine is running it will switch to 12 volt. After driving when ignition is turned off it will wait for 15 minutes before the gas will reignite. This is to allow filling up at a fuel station so no naked flames. If you arrive at a site and plug in 240 it will go straight to mains operation.
Hi Bessy. The isotherm is a 12v / 24 v compressor fridge, so no gas.
I think I’ve solved it now anyway. Cheers
We have a dometic freezer box can go down to -22c but it is a bit heavy on the batteries
