Inverter remote switches
Hampshire, UK
Dethleffs
Since 2017
Hi everyone, looking for some help.
I have a failed modified sine wave inverter that I want to swap out for a pure sine wave model.
Question is, are the remote switch connections to the inverter the same so I can use the old remote?
Ray
Solution2
Ray
Usually needs to be the same brand.
What brand is it ?
Ray
What brand is it ?
Upvote 1
Solution
I've looked a little into this and there seems to be a standard RG, 9 or 11, can't recall which but they look like a telephone connection into the phone itself, not the extending.
That's just the connector they are using it's the software that will determine if it works & the pins may be connected differently.
Ray
It MIGHT do if the jack is the same. I couldn't find a remote to switch mine off. I made my own after watching this YouTube video, there's a bit of waffle but he explains the principle really well. Very easy when you know how and it works a treat, just make sure you buy the cable with the correct number of cores👍
Cheers for that. I did see this and it makes even more sense having watched it again this morning
This is the cable I used
MainCore 2m long FLAT RJ12 to RJ12 (6P6C) Cable Lead Cord / (p.s. RJ11 to RJ11 with 6 wire) (Available in 0.30m, 0.50, 2m, 3m, 5m, 10m) (2m) Amazon product ASIN B07BHNVM2V
I think all that is required to switch most inverters on an off is a remote make or break switch. That is how my Victron works even though it uses an RJ11 cable.
ezee
Think I’ve got the solution.
When my new inverter comes it’ll have its own switch. I can just unplug my old switch, leaving the cable routed, in place and reconnect the new switch/inverter in🙃
