Be sure you know what you are doing when you add a 3000W inverter. I know 3000W is only about the amount of power you can get from a single 13A plug, but it's still an enormous load in an average motorhome. It's too much for a single 100Ah battery, and two 100Ah batteries will really struggle.We have a Rapido 886f and are thinking of adding solar panels and a 3000w scion inverter
In theory, it really shouldn't matter. Laptops use switch mode power supplies, which chops up whatever input it gets into capacitors and then drains it back at the appropriate voltage for output. They don't care if you plug them into a European socket at 230v/50Hz, or an American socket at 110v/60Hz.
Our local substation started to die and lost a phase (and caught fire a couple of hours later). Stuff like the vacuum and fridge did not like it, but my laptop didn't care. Even my main gaming PC was fine until I loaded a game and the power draw was too high. Switch mode power supplies should cope with all sorts of rubbish.
However... I have had an issue running a laptop on an inverter. It was a cheapo 150w inverter into a cheap laptop. Soon after I plugged it in, the touchpad would freeze. Unplugging it so it ran on battery, it worked fine. I don't know why. My work laptop and my wife's work laptop are fine on it.
Our worry is that our apple imac will run ok and not damage it or the power supply over time.
I read somewhere that apple were very sensitive to power fluctuations
Francis
Yes, that link is for a DC-DC converter. Perfect solution especially if you don't want to be running an inverter all the time for something else.I've been a user of Macbooks in vans for may years. The Cheap Option... I have used 12v ciggy lighter chargers like this one for a long time with no ill effects of battery or computer
However, these days everything works off a quality inverter![]()
I don't know about iMacs, I only ever use a standard PC-type laptop. But from reading the specs, even a 27" iMac only has a max power consumption of just less than 300W. So a 3000W inverter is definitely OTT for that.Hi folks... sorry for an misunderstandings but its not a laptop (Macbook) computer but a full desktop (iMac) with built in 21inch monitor I want to use.
Yea the invertor is pure sine wave and I have been quoted for is around £1000 so hopefully it should be fairly strong. Just need to get the power to work it through solar panels and batteries... and in Donegal, Ireland that could be a problem!
