If I bought a Lithium battery what would be needed? (1 Viewer)
Mar 21, 2010
2,429
2,894
if I bought a lithium battery to replace my two 100am batteries, what other costs would involved? I know it’s not a case of just swopping over.
I have 2017 Hymer. Fitted with two solar panels but no inverter.
Could I fit this myself and what should I look out for?
Colyboy
Jun 6, 2012
1,100
1,457
Leeds
Since 2012
If you buy Lithium’s with built in BMS then you don’t need a separate BMS. The only other items to check are your charger(s), are they capable of charging Lithium’s (both the van charger and solar controller)
If not then you will need to change them.
That’s it.
Dave
colyboy
Mar 21, 2010
2,429
2,894
Dave ,
What is BMS.
How would I check chargers Van and solar?
Colyboy
Feb 12, 2018
665
5,339
South Yorkshire
Adria Coral 600SL
Since 2017
Fairly new to the market (I was told at the NEC!), are LIFOS Lithium batteries. These are said to be "swop and play" i.e. no other modifications needed. They also seem somewhat cheaper than other Lithium Batteries on sale, at (only) £700 each. Have a look at https://www.lifos.co.uk/ .The stand promoting them at the NEC was "Sail and Trail". Their website is www.sailandtrail.co.uk .
I have no connection with either of these companies, but have been exploring having two fitted to our recently purchased new MoHo, with a 1500 watt pure sine wave inverter so that SWMBO can use her hair drier and tongs! SMC, from whom we are buying our new MoHo are actively promoting fitting these LIFOS batteries, but I have held off for the moment as expenditure is already exceeding budget!
eddievanbitz
8,008
39,251
Taunton Somerset
RV
since 1989
Even with the cheaper, Non E Approved (Legal for road use) Lithium batteries have to have specialised DC to DC charging Very few vehicles are set up in such a way that a Lithium battery can just be dropped in to replace an existing "non lithium" battery
Feb 22, 2008
12,180
44,231
Norfolk
Hymer B544
Since 2004
What about these , expensive but lighter and effectively one almost replaces two.
eddievanbitz
8,008
39,251
Taunton Somerset
RV
since 1989
Most decent lithium batteries will replace two conventional batteries power wise for about half the weight
On my new van I took out two 100 Ah lead acid batteries that weighed about 35Kg each, and replaced the 70Kg with two Lithiums that only weigh 15Kg each and gives me double the actual, usable 12 volt power
Ridgeway
3,531
5,735
Lausanne
NiBi Arto 85E
Since 2012
Wow that is impressive !
less than half the weight and double the power.
Roughly 3 x the price ?
Aug 19, 2014
1,809
5,316
Cliftonville
A Class Burstner
Since 2014
My Son-in Law is a Fire Officer.
His view is still too many incidences of them igniting for his liking....
Not sure how many is too many but once would probably be too much..
eddievanbitz
8,008
39,251
Taunton Somerset
RV
since 1989
That is why we will only sell Lithium batteries that are E13 Accredited for road use. If there were an issue and the batteries were not legal for road use, I am sure that issue regarding insurance would soon raise it's ugly head!
Jun 6, 2012
1,100
1,457
Leeds
Since 2012
Dave ,
What is BMS.
Colyboy
It’s what keeps all the cells balanced and makes sure that in the event that any cell isn’t within defined parameters then it shuts down the battery, it’s just a little box of tricks and in the grand scheme of things not expensive (y)
