I managed to change the time on the dash clock
after many tries since getting it I finally sussed out how, (2009 Fiat base) I held the Mode button in, the one one the righthand side of steering wheel near the headlight adjustment up/down buttons (with ignition on) I held it in until the display started flashing and then used the up/down arrow buttons to chose function and then press Mode again to select it and the hours started flashing and again the up/down buttons to change, did same for minutes, sorted, you can also change the speed warning limit as well so I set that at 60, happy days, sometimes it's the little things
