- May 10, 2020
- 869
- 3,099
- Hymer ML-t 580 4x4
- Getting there!
Right ho ….. Lockdown 3, The Project ….
I really need to upgrade the Audio in my Hymer Exsis. It’s so tinny it gives me a headache to listen to it. I’ve fitted car audio before so quite happy to get stuck in.
Headunit is a Zenec Z-E3726. Budget doesn't allow to change this - it's not brilliant but I reckon with an amp and better speakers it will sound pretty good. The sat-nav is pretty poor but I can use my phone screen as a sat-nav when needed. I rarely use sat-nav as rather like getting lost a bit from time to time. Music is mostly streamed from my iPhone via Spotify and Radio from the BBC sounds app when we are in mainland Europe.
Speakers are, two Visaton FX 13 4 OHM in the front cab area side panels along with Two Electro dynamical exciter Visaton EX 60 S units in base of the over-cab drop-down bed and two more Visaton EX 60 S in the head-board to the fixed bed in the rear of the van. The speakers are shockingly bad.
I am planning on adding an 4 channel amplifier by connecting to the RCA out sockets on the back of the headunit and then connect the amp speaker outputs to the four speakers - Front Right, Front Left, Rear Right and Rear Left. I’d then connect an active base speaker (or may two) the Subwoofer RCA output.
I figure this is do-able from the Zenec Head unit as I have all the connections needed. So I’m thinking ….
4 Channel Amplifier - Juice Car Audio JA1504 4 Channel 1500W
Active Bass Speaker - In Phase Car Audio USW10 300W Underseat Subwoofer
Front Speakers - Alpine Car Audio Systems SPR-50C 300W 13cm 2-way Component Speakers with Tweeters and Crossovers
Rear Speakers - Alpine Car Audio Systems SPG-10C2 180W 10cm 2-way Coaxial Speakers - These are the only ones that will fit in the back of the van without cutting the furniture.
But … I’ve hit a problem. My TV - an Alphtronic 22” is somehow also connected to the front cab speakers. If I have the Zenec on, turning on the TV will hi-jack the front cab speakers. I then get TV sound through the internal speakers on the TV and the front cab speakers. The Zenec will then continue to play but only on the speakers in the bedroom area. If the Zenec is off the TV will still play through the front speakers.
Strangely the only audio out connection from the TV is a jack plug into the headphone socket. My understanding is, if headphones are plugged in then the internal TV speakers would be shut off.
I assume must be some sort of control switching amplifier type unit wired into the front speaker cables somewhere after the Zenec, but before the speakers.
Does anyone know of such a unit?
I guess connecting an Amp to the RCA output of the headunit and then direct to the new speakers it would bypass this control unit. I don’t want to do that as I want the TV sound through the cab speakers as well.
Any ideas or pointers gratefully received before I start dismantling the dashboard area....
