How to repair locker doors?
Devon / Cornish border
Mobilvetta Kimu 122
Calling on all the Guru's on here for some advice / assistance.
Both garage and gas storage locker doors have deteriorated due to historical water ingress. It was like this when we bought it and is slowly getting worse. No water getting inside.
Now what can I do? Don't want to purchase new doors as may not be available, reasonably handy but how to these doors come apart and what do I replace with? Thinking full on uPVC of right thickness??
Can I remove screws (see picture) and pull apart or is it a full door removal?
Pictures attached
I'd carefully remove those two screws and pull the aluminium trim then replace the wall board with new or some plywood. Refit as before.
Can you not cut out a template for the doors from wood and bolt it through the locker doors, using sealant to waterproof them. Would this pull them straight again.
Think you’ll struggle to replicate them and achieve a watertight seal.
Good luck with whatever you do and post pictures please.
They are straight as they are, didn't want to unscrew and find I couldn't meet enough access.....
Think it's a winter job, do smaller door first, take apart carefully, measure etc
