- Oct 12, 2009
- 11,870
- 26,626
- A Class N+B Arto 69GL
- Since 2009
I have an N&B Arto69GL(2003)
I have read about the adjustment of these headlights and from memory the process is as follows:-
[All references are looking from rear forwards. I know it is difficult to see directly]
There are two 'locking' screws at 3 o'clock and 9 o'clock holding the unit in place. These have to be loosened.
There is a third 'locating' screw at 12 o'clock which has to be removed completely.
The unit then has to be twisted to change the beam. I cannot remember if, for UK to Continental, this should be clockwise or anti-clockwise. Getting it right would make it easier to locate the top screw in the only other hole.
Having located that screw it should be tightened, and finally the locking screws should be tightened.
If I have the procedure correct I only need help with the twist, please.
Thanks in advance.
Geoff
Thanks in advance.
Geoff
