Heeeellllp ! Driving me mad.
Greg D
3
3
Swift Bessacar 596
Can anyone please help .
I have a swift bessacar 596 and preparing to go away tomorrow
All plugged in at home to make sure everything is ok.
An alarm is continually bleeping and cannot work out what it is.
We believe it’s the fridge which shows no lights on but stumped from there any pointers??!!
Have you checked you still have electrical connection, If I plug into our garage outlet it has occasionally tripped our RCD in the garage which obviously disconnects the motorhome which sounds an alarm to warn us this has happened, the fact you have no lights in the fridge indicates either an issue with mains power or the fridge.
Restarted everything and got rid of alarm but still no light on fridge. Checked fuse all good there but no power to fridge still. ! ?
Could be the fridge door alarm, you can check by pushing the spring strip that operates the switch. If it is that take the catch apart and bend the strip a bit.
The fridge light will be 12V not mains, our old one worked if it wanted to, no logic at all, slope or level hooked up or not
Why do you think alarm is from fridge? When you say lights I presume you mean inside, does the controller on yours have lights?
