Hands Free Mystery
appydaze
southend on sea essex
Merc high top
20 years
Hi all, l have recently bought a second hand Jeff Gosling Hand control for the van. Unfortunatley there are no instructions on how to fit it and l am struggling to work out how to connect the accelerator pedal to the sort of wire cable. The brake assembly is pretty straight forward as is just a push to stop, but how to push the accelerator pedal down has me flummoxed. Anyone got any pics. or diagrams that may help. Thankyou. (y)
Thanks Jay, I have seen them but cannot see any detail of accelerator pedal. Thanks for trying (y)
Have you tried contacting them? they MAY even be helpful !
Does it push the pedal or work on the throttle linkage?, just a thought....
Cheers, Dave(y)
Cheers, Dave(y)
Hi Dave, Its a push - pull type with a solid lever to push down on the brake that is easy enough but the accelerator is like a pedal connection with a sort of like a bicycle cable which you cant pull up on because obviousely it has to push down to accelerate. Thanks,Pat
In that case then I would have thought that it either has to curve around behind & below the accelerator pedal & then pulls it downwards , or, ifthe pedal has an upper part which is past the pivot point it could pull on that part from above.
