Fly screen Door cord broken
Suffolk
Chausson 788
20 years
On our Chausson I caught one of the Horizontal cords on the Fly screen sliding door, and it's pull out and coils up when opening door this cord is second one down from the top, the Fly screen cassette is attached to a frame and the frame screws don't look accessible , has anyone repaired one of these please if so can you tell me how to repair it , Thanks
You have to take the whole flyscreen out lay it on a flat surface. Then take the frame apart it will be held together with either self tappers or pop rivets. Then you can replace the cord, I used kelvar kite line you can get it on eBay in various thickness. Make sure you get all the cords the same length. When you get it apart it's fairly obvious how it works and how to do it.
As you have already found out getting the frame out is the hard bit.
If you put 'fly screen repair' into the search box you'll find it has been done.
Hi thanks for your help
Can you remember what thickness you got ,as I purchased 1.5 mm Braided cord and it's way to thick, Kelver Kite line is a Braided line Thanks
