Flogas light @ Costco
Dont own ome yet
Just at Costco and they got Flogas light bottles - anyone got one or ever used Flogas bottles?
I bought one but then found it has a push fit connector, so I would have needed to replace that and get both bottles or have to change the pig tails at the changeover. To do that is close to the cost for a safefill
Edit I got a refund from Costco
We use the ordinary Flo Gas bottles and they are interchangeable with our Calor Gas bottles both have the same fitting but our dealer did tell us we would have to change adapter if we wanted the light bottles
Thank you - I’ve got an older calor lite but they stopped doing them , saw these and thought it may be worth a try !
We use one in the garden for the pizza oven, and before we got the refillables used one in a previous MH. To it with a bulkhead regulator you just need to use a butane pigtail with a 27mm clip-on adapter.
They have a number of advantages over Calor......lighter, cheaper (especially from Costco), and you can see what's in them. Plus, if you travel to France you can use the same adaptor for the French Le Cube bottles if you you run out. If we didn't have the refillables then I'd definitely be using them.
