Fitted table won’t lower
Janecambridge
Burstner
3months
Burstner ixeo 680g. Fixed table lowers and swivels. Last night unable to push table down enough for bed to be lowered into it, in line with seats. And ideas?? Thanks.
Give Camper UK a call Im sure they will have the answer. 01522 411252
Check the leg doesn't bend back underneath the table. Then lower to the table lowers. You may even have a short support leg somewhere in a cupboard. X
The one central table leg is solid apart from raising/lowering of table.The table will not rise to full height.
my husband rang Camper UK and told them he is happy to do repair work as he is competent and still able to crawl under tables. !!
They were helpful but sounds like it needs a new table and leg,Over £500! That’s huge money for us..
Anyone got a spare table and leg??😂
Oh dear.seen there has been welding done under table.may need to completely remove table and get a stand alone one,
Is it like this lever on our Burstner??
Turn it through 90° and press very firmly on the table directly above the telescopic pillar.
Beware, when it goes, it goes quickly... We always remember the salesman landing in a heap on the table when he demonstrated it :roflmto: :roflmto:
Good Luck
Barry
Thanks Barry. Not same lever. It’s a flat lever.
Sit on it. Sometimes they take a bit of grunt to push down.
The weight of a person carefully sitting on it will assist it downwards.
It’s broken.it has something preventing internally going down.Spoke to another Burstner seller and they think it can’t be adjusted,seals gone.Will need to replace.may look at removing it totally somehow and getting solid caravan table.
Totally wrecked so removed very carefully,with no damage.Have bought a very good secondhand caravan folding table and put the legs on our original table top.Looks great but need a new carpet as original has whole in centre,😆
Thank you for your help.
We've taken the big table out of our MH and put in a smaller one. We also have a hole in the floor where the table leg was. Have filled it with a block of wood and covered with a furry rug. Looks good and it's warm!
All we have is 4 (barely can see) screw holes!
