Engine in van
Plantox
Pilote galaxy 40
I have a 2001 pilote galaxy 40 it apparently the engine is a 2446cc td does any one no anything about them engine code ? I have been told my injector is over fueling tried a flow test but no fuel coming out can any 1 help thanks
2446cc is the engines cubic capacity....commonly known as a 2.5ltr
TD means turbo diesel.
If it's over fuelling the injectors, 4 of them, need either servicing or replacing.
There can't be no flow if it's over injecting....the flow rate will be higher than normal
Perhaps you could tell us who told you it is overfueling.
Is there any smoke from the exhaust, please check on Idle then while driving up a hill. If so, is it blue, black or white.You may need someone else to look for you.
Blue smoke could be engine oil burning, perhaps past the turbo seals.
Black is overfueling.
White is unburnt fuel, this will probably only be from one cylinder and may feel rough.
It is white smoke thanks
Have you been to a diesel specialist.
Hi. Try changing your fuel filter. I had lots of smoke & low power on hills. Turns out I may have had water in fuel. Problem cured by simply changing fuel filter. Simple job too.
