Door handle / lock
Zepp
Roaming
7 Years
Anyone know where I can get one of these door handle / lock from .I will try and get it done under warranty but not sure I can afford to wait that long lol
Only Part number I can see is PA6GF30 I think they are made by Hartal
The opening bolt has snapped see picture 3
Thankyou in advance
Not sure if it helps but the door looks like a Hartal Evolution
If it’s anything like trying to source other Hartal parts, the only option is a new door!!! That’s what I was advised when I needed a part, but luckily I found a replacement via a caravan breakers
Have you tried Go European?
When the outside part on the door lock failed on ours they had the part in stock and fitted it while we waited.
Richard.
Have you tried re-attaching using one of the metal repair putties?
Richard.
I give up with Go European Richard they never return phone calls or e:mails complete waste of space Im still waiting for them to do the warranty work
Contacted Chris at reliance hoping he gets back to me today but I need it fixing asap cant lock door
Suggest you email Chris Davies (parts manager) at chris@reliancecms.uk with pics.
Reliance near Chichester are now approved by Carthago so should have access to their database.
Edit: beaten by Zepp !!!
Im a big fan of Chris he was my first port of call , waiting for him to get back to me , If anyone new where I could order one from I was going to get it and fit myself .
Yes, Chris used to be very helpful when he was at his previous employer.
He used to post and help people a lot on that other forum that shall remain nameless. :)
Richard.
Richard.
He still is very helpful. I emailed him recently, Sunday night, and internal cabinet lock arrived Tuesday morning. How's that for service :D
He sourced it from Nova Leisure, a supplier not accessible to the general public.
Quick update Chris got back to me and he is going to order one for me, it might be 3 to 4 weeks but its a start .He has put it through Carthago Warranty .
I will keep looking and buy one if I get a chance as I don't have any faith in the Carthago warranty ( been waiting a year for blinds )
Temp fix 117k for a motorhome and I have to use a set of allen keys for a handle , you have to laugh or you would cry welcome to the motorhome world.
Can’t your supplying dealer send you one to fit yourself ?
Ho Robert
I gave up with GMC they are a complete waste of time they don't reply to calls or e:mails , Chris at reliance has started a warranty claim for me. I may have a contact in Germany I will buy one if the warranty claim drags on .
Ho Robert
Hopefully it’s a stock item for the dealer and doesn’t have to come from Germany
Think we had the same issue with our Carthago. Could only open the hab door from one side
Hope so Robert but I contacted 3 dealers today at 9am only Chris came back to me
i would try gluing it then reinforce the repair with 2 part epoxy putty
Hi,
I currently have a problem with opening the hab door from inside, can I ask what happened with yours in this post please?
Hi,
Sadly Zepp is no longer a subscribing member, so can't reply. The plastic inside the mechanism clearly snapped, so a replacement was the only solution. It does seem ridiculous to put that much stress on a plastic pin, even though it is reinforced with webs.
If it were mine and with nothing to lose, I would cut away the broken part and weld in a metal rod to recreate the pin. With the advice from another member, I recently rebuilt a snapped pin on my outer handle, using a small bolt. So it is now stronger than the OEM part. Sometimes you have to think outside the box as it were and solve the issue that the manufacturer failed to do
Yep, like the crap plastic door hinges on Hymer's they want £120 each for a pile of poo. I had a batch of stainless steels ones made at a fifth of that cost and supplied other Funsters with them.
