Dometic RMD 8505 on gas - dumb bunny moment - reset button
Suffolk, UK
Rapido 9048DF 2016
Just in case anyone else encounters this.
Getting the Rapido ready for a few days away.
I decided to check that the fridge works on gas (we rarely use gas, but...).
Turned the gas on, checked the crash safety valve was open, lit the hob to make sure gas was flowing.
Manually selected gas on the fridge control panel.
Beeping and red flashing light.
Left it for a while but it was still beeping so I connected the EHU and it was fine on 240V.
Reading the manual (actually looking for how to remove the external cover to check the gas jet) and noticed that there is a Reset button GAS FAILURE.
Ummm....selected gas again, beeping and red flashing light, pressed the Reset button and all was quiet.
Oh.
Hi I have had a similar problem .Could you tell us where the reset button is located.
many thanks.
many thanks.
On the fridge door I think. Will check later as I think I've a 8505 as well. I get the same issue. Fridge is on other side of camper and gas takes a long time to get to it.
