You havnt left the window open in some rain have you or door not fully shut.First service today 40% damp found just behind driver's seat.Year old van not good enough really fed up will get it fixed then goodbye Autotrail.
oh dear.. that is bad... let them repair under warranty and then have a good think... dont jump out of the frying pan into the fire, this could have happened with any brand.First service today 40% damp found just behind driver's seat.Year old van not good enough really fed up will get it fixed then goodbye Autotrail.
Incontinence pads sprung a leak??First service today 40% damp found just behind driver's seat.Year old van not good enough really fed up will get it fixed then goodbye Autotrail.
Thanks for all your kind words of support I'm contacting my dealer (who i have confidence in after other repairs carried out) tomorrow to start a warranty claim.
Now I've got over the shock we'll see how the repairs turnout before deciding about getting rid of the van.
Could it have anything to do with the electric lead inlet being there? Perhaps the seal isn't sufficient to stop water getting past it?
I read the other replies so didn't state them again but no-one mentioned the electric point, hence my suggestion.That's a very good point Mel but the three main problem areas which result in damp behind an Autotrail drivers seat are:
1. Front leaky window.
2. Poor join-integrity between floor and wall (very common).
3. Failed vertical seal between cab and conversion (also very common).
There have been many dozens of reported damp issues behind Autotrail drivers seats but the underlying issue is down to the poor build quality of the conversion.
You can get clips to go on the joints to stop them vibrating apart. Done all mine. Think they are called collettsAutotrail's have john guest speed fit type semi-flexible plastic pipes with a micro-switched pump. I have seen a few Auto-trails pipes that blow apart with the water pressure. The pump micro-switch then kicks in and all the water in the motor home water tank will leak in to the van.
If I had an Auto-trail I would tape any water pipe joints up with gaffer tape to stop them from coming undone. eg, T joints, Y joints, straight joints etc
Hi MartinYou can get clips to go on the joints to stop them vibrating apart. Done all mine. Think they are called colletts
john guest collet clips.Hi Martin
We have an Autotrail no real problems as yet but can you let me know where you got them from and a photo if possible.
Regards Ray
