Cost-Effective Alternatives to Thermofloc
Citroen Relay
On and off since 2011
Without wishing to raise the thorny discussion of vapour barrier or no vapour barrier, I am looking at installing a permeable membrane as used by roofers and others who know what they are doing. I on the other hand, do not. In my undecided and confused approach to all things and wishing to show no commitment to anything, it seems that something like Thermofloc is an acceptable way of sitting on the fence. Only trouble is it is so expensive. Are there suitable alternatives that cost less?
It appears to be loose fill?
Even if fully stuffed in to all cavities, I would think it would settle after being driven about, and leave voids at the top?
Thanks for the reply. It is in fact a variable membrane. I’ll edit my post to make it clear.
Unable to edit but this links to it:
That product is certainly expensive. At 37.5m squared @ £113.41 +vat. £137
50m squared @ £69 +vat. £83
Which is a product I’ve used or even cheaper
So not a vapour barrier?
I'm afraid I don't know enough about converting vans to have an opinion.
Thank you. That's helpful.
Thanks. That's helpful.
Thank you. A more affordable option definitely.
Im certainly no expert, but looking at the products mentioned, Thermofloc is a Vapour Control Layer for the inside layer, whilst the others are permeable layers for the outside layer.
You do not want a permeable layer as this will allow moisture through. The permeable products stop rain coming in, but allow vapour to go through. VCL stop the vapour coming through.
Thanks for that. I've been going round in circles over this for ages. I'm tempted to become a Greg Virgo disciple and use thermowrap as a barrier but given my level of skill I think it unlikely that whatever I install would achieve its intended purpose.
Thermowrap is certainly a product that could be used as that is its intended use. The idea is to try to stop any vapour/condensation from reaching the insulation and bare metal. Therefore the material has to be non-permeable. So you wrap with Thermowrap or other equivalent and use aluminium tape to join the seams and holes where cables come thorough etc.
