Scout
- Apr 4, 2009
- 4,009
- 142,880
- chic c line
- 12 years motorhoming, a lifetime of living
My alphatronics 32” sd-cr tv didn’t work during my pre journey check yesterday,
Media unit is on, but the voltage is showing only 9.5 volt ? at the tv plug
Knowing the tv is probably wired to the cab battery as standard? As it is on Carthago’s I was concerned about the cab battery despite the reading on the top display showing 13.2 volt, also the same on my telemetrics app
The cab battey is showing 12.7 volt at rest, but 13.2 volt on charge (mains +solar yesterday )
I charged the batteries overnight and the they were showing cab 13.2v hab 13.7v this morning
I checked the power at the tv plug which was 13.2 volt.
I plugged in the tv , nothing no power light, I made sure the tv on/off was not sticking, changed the remote batteries .
After removing the tv I rechecked the plug voltage it was showing just 10 volts, but still 13.2v at the top box display.
I waited an hour repeated the process and the results were the same, after plunging in the tv, unplugging the volts dropped to 10volt
The van starts first time, on checking the readouts when the engine is running + a bit of solor as its sunny, cab 14.2v hab 14.4v , tv power plug 10v
As the tv has a weird size power jack I can’t try it elsewhere without cutting out the plug from the wiring.
Is the tv duff, have I got a “going bad” cab battery or something else.
Opinions
Opinions
