PJGWiltshire
Carthago chic c line wiring.
A challenging tail of woe. Set off yesterday afternoon for an unplanned weekend away. Fully loaded and fridge on gas prior to setting off. We set off, no apparent reason to think the fridge has not automatically switched to 12v when running along. Stopped a few hours later for meal.
Stay with me now.
Having turned engine off got on with filling kettle to burn on gas along with another burner. So two ignitions start without issue. A minute or two later used third burner and the ignitor just stays stuck on. Burner lights but when releasing small knob ignitor still cracking away.
Just can't stop it so pulll draw out intending to see if I can pull the wire from the ignitor. Cannot pull wire. Now it is at this time I hear very faint bleeping from the fridge .
This would be about five or six minutes after engine ignition stopped, so at a time for the fridge to now automatically allow itself to start up on gas. The fridge panel Dometic tower fridge/oven lights are all off and there is a very faint glow from the power metering bar very low in illumination again with the very faint alarm bleep.
Still wiggling whatever I can under the hob the ignitor then stops cracking. The fridge is still in faint bleeping mood and the fridge control panel is still not lit up and fridge is not working..
Pressed fridge control board off buttonf Bleeping stops. Turn fridge on, no power up but agin faint illumination and faint warning bleeping again. Tried hob again ignitor stays stuck on again for some time then stops again. No change from the fridge.
Turn fridge off.
Leave for about 20 minutes. Turn fridge on again, no change as before very faint alarm sound. Try the hob, No ignition from any of the three burners on hob. Then very faint clicking sound coming from the oven area of the tower oven. This faint clicking stops when you push the over ignition knob but starts again when let go. Also the fridge faint bleeping has stoped completely with the ignition clicking going on. The fridge tower oven ignition faint clicking goes on for about 40 minutes then stops. After stopping the alarm bleeping form the fridge panel starts again immediately until I turn it off.
Now has anybody any idea what maybe going on
As off now, Turn fridge on still faint alarm bleep. Try hob ignition no clicking what so ever for hob or from the tower oven. Fridge turned off
Hob has power to it checked with multimeter. Fridge obviously has power to it.
I suspect the fridge PCB is toast but how could this happen.
Any ideas.
Stay with me now.
Turn fridge off.
Any ideas.
