Burstner Aviano owners....can you help?
MB-B90
Solihull
Burstner Aviano i727
Cut our teeth now……so just above useless!
So I’ve brought my i727 home for the first time for some work to it.
Thought I’d keep it home today until taking it back to storage tomorrow to get to learn how to use it.
Got it hooked up electrically, filled it with water. Got heating on electrically too.
Thought I’d run the water through the taps but every time I switch the pump on it starts draining the water.
I’ve checked the two yellow toggles next to the pump that they are horizontal and the diamond shaped switch is turned so the button is down ....but I’m wondering if it needs to be reset due to the frost control on the Truma pump? Could this be the issue? Although the temp on the panel is showing 14’C.
I’m stuck so some help would very much appreciated.....many thanks
Reset button at the bottom of the valve --- Blue model
Oh great thanks, I’ll have a look at that in the morning!! 👍
Yes, done that, thanks Gaston.
I’ll reset the Pump this morning and hopefully that will sort it.
