Bedroom and Lounge lighting
Kent
Swift Kontiki 794-23
Since 2010
All of a sudden the rocker switches in bedroom and lounge have stopped working? Not sure if just a coincidence, but as per image a cable dropped down in passenger well. I wouldnt have a clue if thats related? Checked 7.5 amp fuse and circuit breakers and all seems fine
Steve
Steve
That doesn't look original, and it seems to just have one wire, see if you can see anything it might connect up to? Having recently removed a large chunk of my dash I was surprised how many connectors there are that don't actually connect to anything!
As for the rocker switches, can you remove one to test the switch itself, albeit that it seems strange they would both 'fail' at the same time, although they might both take their 'live' from the same source?
Thank you, I will check, just another note, when we go to bed we use the internal lock button on dash to lock up
when I awoke this morning I pushed button to unlock and the lounge lights came on and then went off after about 30 seconds which is normal and then i ususally push the rocker to switch back on, so the lights do actually work in lounge but not via the rocker and strange that bedroom lights rockers and have also stopped working
Thanks again
Thanks again
Problem solved and thanks to all
Hi Steve,
Thank you for your email. This sounds like X5 (switches input) may have become loose at the rear of the PSU so your dimmer switches aren't working. Please pull the PSU forward from its housing and check the plug to see if its fully flush in the board. Beyond this if the fault persists please let us know.
