I’m pretty sure it’s 16 mm2 with about 2 mts length.At what load? What are you running of the inverter? What size cables from inverter to battery, and what batteries?
The inverter cable is 16mm2? Look for bad connection to inverter. As you turn it on, it charges the caps and it creates a surge for a second. This maybe is bringing the voltage below alarm setting.I’m pretty sure it’s 16 mm2 with about 2 mts length.
And strangely it does it without a load, just when I turn the inverter on.
Will have a check tomorrow.The inverter cable is 16mm2? Look for bad connection to inverter. As you turn it on, it charges the caps and it creates a surge for a second. This maybe is bringing the voltage below alarm setting.
