What type of booster and aerial do you have? Red flashing probably means something is wrong or the aerial needs adjusting.There is a red light flashing on what I think is the booster.
You need to help yourself by posting some pictures of your Aerial, Booster, TV showing source etc. We are not mind readers, it may be that you were lucky putting the aerial up and it was lined up with transmitter, or maybe yo have accidentally turned the booster off or wrong source on TV.The Tv is 12 volt. The signal is fine on the TV in the house. The TV worked on our drive before we set off and also on our first night on sight then nothing the second day
Ok so Tv is working fine . Co ax or booster needs to be looked at now .The Tv is 12 volt. The signal is fine on the TV in the house. The TV worked on our drive before we set off and also on our first night on sight then nothing the second day
Think he's saying that as the TV is 12volt he hasn't tried it on the house aerialOk so Tv is working fine . Co ax or booster needs to be looked at now .
I think the flashing red light on the booster probably indicates a problem.Ok so Tv is working fine . Co ax or booster needs to be looked at now .
From #1 it seems the Avtex powers up ok but auto tune doesn’t find any stations.There’s a cunning on off rocker switch on the bottom of Avtex tv. Very easy to accidentally trip.
If the switch is okay it could be that the coax is at fault.There’s a cunning on off rocker switch on the bottom of Avtex tv. Very easy to accidentally trip.
Hi, Have you sorted your problem yet, I am an AV engineer by day and have just stumbled on your post and may be able to give you some advice.We had Avtec television on one night while away. Tried the next night no signal I think. Tried auto tune not bringing up any tv or radio programes. Moved to different area still same also tried it today back home still same. Any ideas please.
Good luck he has ignored all other offers to helpHi, Have you sorted your problem yet, I am an AV engineer by day and have just stumbled on your post and may be able to give you some advice.
Quite agree but he has just ignored any suggestion or request to upload some photo's of what he is seeing which always helps IMHO.One of the problems is that with fault finding, you have to follow a logical thought process, quite often when people throw all sorts of info, solutions and advice (sometimes bad advice) in to the head of someone non technical things normally just get worse. I see it all the time in my day job.
