Autotrail tracker 2006 bed modification
DerekJ
Autotrail Tracker
Has anyone managed to modify the bed arrangement to give two single beds utilising the front swivel seats could the wooden partition behind the cab be cut away?
That 'wooden partition' is structural, it's a fundamental part of the joint between cab and habitation area. Don't touch it!
You can't cut away the partition for the reason given above, however you could just pull the sofa bases & cushions out a bit, drop the back cushions down behind the base cushions and that would then allow you to sleep straight with your feed on the cab seats, still leaving a bit of a gap between the beds to enable you to get in/out, failing that just sleep at a slight angle (put some cushioning/pipe insulation on the edge of the partition so you don't get bruises!).
