On Julie's car it means it is off but not sure about other motorsAirbag when using child seat.
Not sure if warning is telling you to disable the airbag
AFAIK, an airbag warning light is an MOT failure, so get it looked at.Thanks everyone for replies, checked on the van computer thing and the passenger air bag was turned off. Switched it back on and the light is still on! As long as it's not dangerous and the airbag is on I think I'll ignore it. How about you.
I read the illuminated symbol shown on the OP to mean the opposite, i.e. the “Passenger Airbag is deactivated”, (which means one can safely put a rear facing child seat in the front.)Think it means no rear facing child seats unless you turn airbag off
Or it could be a fault with the airbag ECU.if the passenger airbag is set as on, and the light remains, i think it is indicating a fault with the airbag
I’m coming to the type of parties you go to!There's something faintly saucy about it...............
****just don't have an accident with anyone in the passenger seat at the time, in case it doesn't deploy if requird.....Or it could be a fault with the airbag ECU.
I would drive it for bit it may go out, may just need a bit of time to reset.
Its similar to this one I saw in china
