- Jun 18, 2019
- 64
- 35
- Hymer B680 Starline
- Im a newbie
Is the electric symbol showing on the control panel to confirm it is present? If not, you may have a tripped mcb or a switch somewhere.
If it is present make sure electric mode is on.
The settings look ok but I can't tell if the hook-up icon is lit up on the right hand panel.... are you sure you are getting power from the hook-up?The panel on the left is the Alde one. I can select 1,2 or 3 KWs but it makes no difference.
You don’t say which country you are , if abroad the available power is sometimes as low as 6amp but in the UK can be upto 16amp which would allow you to set the power on your system higher and give you heat.
Gas is far better in providing efficient heating and once the MH is warm it doesn’t eat gas so not necessary to worry.
Have you switched on electric on the Alde panel?
As per post 4, if you have a load monitor on your Alde system and its set to 16 amp, unless the site hook up provides that, the system will not work on electric. The monitor can I believe be set to 6 10 and 16 amp.
So something to check and also whether the site is indeed proving 16 amp as you have said, if you do have a load monitor.
There is no symbol for the electric showing.
They are usually on their own breaker, check the fuse box.
Brilliant, thanks, it had tripped. Now have the electric symbol
