- Mar 6, 2020
- 112
- 77
- Adria matrix
- 13 years
We have a problem with the Hab door locking/unlocking.
The door can be locked and unlocked( sometimes with great difficulty ) using the habitation key but wont lock or unlock using electronic means.
If I use the integrated sigma alarm fob it activates the alarm and locks/unlocks the cab doors but does not move the inside handle on the hab door to the lock or unlock position although it make the right 'loud clunk' noises of the electrical actuator mechanism inside the door operating.
If I open the door and activate the locking latches at top and bottom of the door (to simulate the door having been closed), then use the Fiat key fob to lock and unlock the motorhome doors the hab inside door locking handle sometimes 'twitches' as if trying to unlock but does not move enough to actually unlock it.
If the door inside locking handle is placed in the unlocked position and the Fiat key fob used to lock it the locking handle does not move but as above the loud clunk of the lock actuator can be heard.
The MH went in for its habitation check at Geoff Cox yesterday and after mentioning the door problem they tried lubricating the door lock, checked electrical connection/crimps to the door and tried adjusting the door position and were of the opinion that the actuating unit is maybe ok as they usually stop working completely when they fail.
They could not diagnose the problem further and suggested it could be a problem with the alarm system ?.
I am unable to find an Adria dealer who can accept a booking to look at it until later this year or 2022 at the earliest as they are all so busy.
It was explained to be that the door can be dismantled but its a sod of a job and held together with double-sided tape !
When I first noticed the issue it explains why we were setting the alarm off occasionally and thought we had not locked up properly when the hab door was found to be unlocked with the alarm activated.
Initially the locking handle gave a good twitch but failed to move far enough but now it does not move at all, just the loud clunk as if its operating the mechanism.
Because I have problems locking and unlocking with the hab key I think there is a mechanical problem with the mechanism, maybe the operating rods or actuating lever somewhere inside the door.
I would like to take a look at the mechanism but cannot find a way to get the door apart ....there are no visible screws holding the back panels of the door to the front of it, I can only see the 2 screws that hold the main closing handle to the door ?
Does anyone have an idea how to get the door inner skin apart or have an idea what could be wrong ?
Also who is the manufacturer of this door to maybe obtain a diagram of its construction ?
Any help appreciated
