I have a Burstner Eliseo which uses a Schaudt. 119 Elektroblock. There is an intermittent ground short on the 2 amp circuit, fuse next to leisure batteries. When fault exists I have a dead short to ground on the output side of the fuse. I've checked cable continuity and to earth from fuse to block 3 pin 5 and ok. Disconnected L100 outputs to water x 2 sensors but no difference. Currently all working ok ( left water sensors disconnected) and waiting for it to fail again to continue fault finding. Any help much appreciated.
