12v volt not working, but only on this device
Marquis Majestic 115
June 2019
Hi,
My 12 volt on this C-Line Module - 12v 6amp Cigarette Type Socket w/ TV RF Coaxial has stopped working, all the other 12 volts on the motorhome work, cab and habitationincluded, I have removed the device and replaced it, but still not working, have had access to behind and although many cables behind, I could not find any inline fuses, have checked all other fuses in the fuse boxes and they are all ok.
Would anyone had this issue and found out why only this device does not work, have tested the 2 cables going to the rear of device and no power coming to the device.
Any help would be appreciated
If no power coming to it then it must be a cabling problem or a simple fuse. I don’t know your van but fuses tend to be near the battery or in the power supply / distribution unit. Would this item have a dedicated fuse? 🤔 possibly a poor connection to a bus bar. Someone that knows van will hopefully be along soon. 🤞
