Yet another Radio wiring query
Discussion in 'Tech/Mech General' started by bertiebasset, Mar 18, 2015.
  1. bertiebasset
    bertiebasset Funster
    Jun 16, 2014
    299
    290
    NOTTINGHAM
    Hi all, I have searched through the threads and read 9 pages but cannot find a real answer to my question. I replaced the radio in my Autocruise Wentworth (55 plate boxer) because I really wanted USB and SD card facility. Problem is there is no Acc. position on the ignition and do not like leaving all ignitions circuits energized when listening in the evenings. My initial thought was to power from the Leisure battery but then thought: radio circuit.jpg
    with this circuit:
    when the ignition is switched on (for travelling) relay 1 is energised removing the power from the leisure battery, relay 2 is energised making power from the vehicle battery.
    Ignition off breaks relay 1 which then picks up power from leisure battery, dand relay 2 which breaks circuit from vehicle battery. when ignition off there is no battery drain as both relays are in off state. I would fit fuses on pick up from batteries and a switch from leisure to cut off radio completely. The memory wire (yellow) would remain as is. Relays mounted under bonnet.
    Anyone see a problem with this. ??
    All comments gratefully received.
    Robert
  2. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,569
    3,375
    Telford, Shropshire
    You don't need the relay. Wire the permanent supply from the leisure battery, fit a switch in a convenient position with a fused supply to one side and the other side then connects to the ignition trigger wire at the radio. you need to fit two diodes into this, one on the original ignition trigger wire and the other on the new feed to prevent leisure/engine battery cross connection via a small wire. Doing it this way retains ignition on/off triggering of the radio but allows you to listen to the radio when on site without having ignition on.
    D.
    • Like Like x 2
  3. bertiebasset
    Jun 16, 2014
    299
    290
    NOTTINGHAM
    Hi Dave and thanks for the input. Do you mean to just solder in a diode in line ? Like a Y join.and is it just a standard blocking diode ?
    Robert
  4. dave newell lvs
    Oct 31, 2008
    2,569
    3,375
    Telford, Shropshire
    Yes exactly like that, it is to block current being passed from one battery to the other via a thin wire. Once soldered in simply insulate with heat shrink tube.
    D.
    • Like Like x 1
  5. bertiebasset
    Jun 16, 2014
    299
    290
    NOTTINGHAM
    Thanks Dave. Just been on fleabay and there are several. I was thinking either a dual schottky diode 10A 135V or similar single.
    Will get sorted at Maplins tomorrow.:)(y)
  6. Xabia
    Xabia Funster
    Jan 20, 2011
    758
    500
    Rural Nottinghamshire and Spain
    Hi Dave, a question From an electrical numpty - is this a suitable diode please:
    ZPY12 Diotec Zener Diode 1.3W 12V
    Have just fitted a DAB converter to a Pioneer double din stereo because the reception in my Hymer is not the best. Used an external Kinetic glass mount and the reception is fine - that's until the ignition switch is turned to the first position and before the starter is engaged - reception is then lost totally. Wired from leisure battery to switch in cab, memory from original yellow wire.
    No diodes fitted - could this be the problem?
    Mike
  7. dave newell lvs
    Oct 31, 2008
    2,569
    3,375
    Telford, Shropshire
    You don't need a Zener diode, an ordinary one will do nicely. The diodes will do nothing to alter reception, their purpose is simply to prevent back feeding current from one battery to the other via a thin wire. I don't wish to be rude but if you really are "an electrical numpty" then its time to put your hand in your pocket and let someone who knows what they're doing sort it for you. You only need to make one mistake with the wiring and you could cause a fire which your insurance won't want to know about!
    D.
    • Like Like x 1
  8. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,138
    15,083
    Leeds the one up North
    [​IMG]
    • Like Like x 3
  9. colinw
    colinw Read Only Funster
    Feb 1, 2015
    525
    306
    Bolton , Lancs.
    I've put a radio in my van , its wired up to a permanent live from the cab battery . the radio has its own on/off switch . with careful use I don't envisage a problem with a low cab battery . we will see ! .
    When I say " I've " , I mean I watched my auto electrician friend !
    • Like Like x 1
  10. Moodybrook
    Moodybrook Funster
    Jul 7, 2013
    784
    642
    Dumfries
    My retro fit radio, actually an Aldi special has an on/off switch.
    I can not get a grip on why it needs to be connected to the ignition at any time.
    I wired mine direct from the veh batt. (it was handy) with an in line fuse. Seems to work !
    What am I doing wrong ? Just seen Colinw 's post So Snap !
  11. bertiebasset
    Jun 16, 2014
    299
    290
    NOTTINGHAM
    Doing nothing wrong Moody. My needs are the same as your except I want to be able to control with the ignition switch as well as being able to switch off from the habitation area. The way I will connect is for power to go to the radio from the ignition but when on site it can be switched on without having the ignition on full (I do not have an accessory position on ignition switch) all the time, but would like it to keep functionality for when I am driving. I will need to remember to turn switch off from hab. battery but no harm done if I forget. :whistle:
    • Like Like x 1
  12. bertiebasset
    Jun 16, 2014
    299
    290
    NOTTINGHAM
    Techno, Thanks for photo, cleared up my thinking lots. One thing,, what size diode did you use (if you can remember). Maplins have schottky 3A 14v (20v max block) or dual schottky 15A .
  13. dave newell lvs
    Oct 31, 2008
    2,569
    3,375
    Telford, Shropshire
    Thanks Andy, a picture worth a thousand words :)
    D.
    • Like Like x 1
  14. Techno
    Jul 28, 2010
    14,138
    15,083
    The wiring is done by Rapido not an upgrade of mine.
    It is as Dave suggested.
    The Red/Green are Rapidos wiring from the CBE distribution unit and Aux switch on the overdoor panel. Note the Yellow from the starter battery is disconnected and replaced by the red from the leisure batteries. The red via diode is cab ignition and the green via diode is from aux switch.
    Picture of diode
    [​IMG]
    • Like Like x 1
  15. bertiebasset
    Jun 16, 2014
    299
    290
    NOTTINGHAM
    Thanks Andy,, they appear to be 6Amp which would be correct as I will be putting in 10Amp fuses. Maplins tomorrow it is then. kerching kerching :D
  16. scouse272
    scouse272 Read Only Funster
    Nov 15, 2014
    77
    132
    golborne
    what language is this?
  17. bertiebasset
    Jun 16, 2014
    299
    290
    NOTTINGHAM
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
  18. bertiebasset
    Jun 16, 2014
    299
    290
    NOTTINGHAM
    Hi all,
    Well, all the bits of cables,, fuse boxes etc have arrived and I have been out to wire up this radio.:cry::cry:
    Managed to blow 2 fuses.
    This is what I have.
    1. From leisure battery to switch, to 15a fuse, to diode at rear of radio.
    2. From ignition switch to diode at rear of radio.
    3. From diode(s) to radio.
    Turned on ignition, radio on, turned on leisure battery switch,, fuses blown.
    Now, checking the wires on the din plug at rear forgetting the speaker side,
    I have on top row,,
    thick red ( + perm). Blue (for power to aerial), blank, white
    bottom row
    thick black (earth), yellow,thin blue/yellow ( + switched) blank.
    on the rear of radio itself is top: pin, pin, blank,blank. bottom: pin, blank, pin, blank.
    so only 4 wires being used: perm + red. earth black, blue aerial, blue/yellow switched +
    Having blown a fuse I have now disconnected the diodes. tried wire direct from ignition to perm red +, radio works.
    removed ignition wire, connected from leisure battery switch to perm red +, no radio unless ignition on but if I turn off the leisure battery switch the radio goes off.
    I am putting the perm + red (as this is a thick wire and all diagrams I have looked at put this) as the switched feed and a yellow as the memory feed.
    Could it be the thin blue/yellow is a switch feed from ignition so need to be using this as the control from ignition/leisure battery.
    All help gratefully received.
    Robert
  19. bertiebasset
    Jun 16, 2014
    299
    290
    NOTTINGHAM
    Now sorted. It was the thin wire I needed to cut into.Robert:)
