X250 - fitting a lighting board to 2010 Boxer (1 Viewer)
arthur49
112
168
Perth, Scotland
PVC
30+ years
Our rear mounted cycle carrier means lifting our bikes to head height and as we get older this is becoming a challenge. Cycle carrier has a lower mounting point which reduces the lift considerably but means we partially obstruct rear lights so I need a lighting board.
Question - I cannot see readily available electrics so that I can fit a socket to accept the lighting board plug. Can anyone let me know their experience? Is there a simple way to fit a socket?
Arthur
SandJ
1,799
818
North Yorks
Too long lol
Arthur
Ask on here lif you get no help
swift-talk.co.uk
Good luck
Gonewiththewind
846
36
Lancashire
July 2007
If you purchase your female plug from any outdoor caravan shop etc, you will find it is attached to a length of cable, with full instructions. You will also require a number of scotch locks for connecting to system. or Go to a tow bar specialist for connection.
Don
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
the X-250 is on canbus electrics so you will need a 7 way bypass relay to avoid problems with the canbus system any towbar fitting place will be able to supply you the stuff you need
43,329
49,445
you may also find a plastic joint box fixed to the rear chassis, if the lighting wires have been extended.....which they probably have.
this is a good point to fit the new wiring loom and relay.
A
arthur49
112
168
Perth, Scotland
PVC
30+ years
Thank you all. I'll get an auto electrician to fit I think. The Canbus issue had not occurred to me:Doh:
Arthur
