Wiring spare battery? (1 Viewer)
Touchwood
772
733
NE England
Compass Avantgarde 140
5 years and learning
I carry a spare habitation battery, but currently its not wired in parallel with the main habitation battery as they're different sizes and I understand that they would need to be the same to have them permanently connected.
I wonder, however, what would happen if I wired them with a switch in the circuit so I could switch between them? I could then alternate them easily by flicking the switch. All advice welcome.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
It would work:thumb:
But dont get totaly hung up on same size batterys
Yes its good best practice
example 100amp + 100 amp = 1 big 200amp battery
example 100amp + 80 amp = 1 big 180 amp battery
still better than your 100 amp single
Charging might be slightly altered but no biggy in my opinion we will get the purist view though im sure
11,956
16,571
Agreed - I'd simply wire them in parallel.
43,348
49,550
as Geo said........
your charger and 12v system only see one large battery, not a myriad of different sized smaller ones.
the only time it could be detrimental is if one battery is failing and has a lower capacity than it should have, then the better battery wont fully charge either as the combined voltage and amps will fool the charger into thinking the BIG battery is fully charged
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
I had a mechanic do this to our MH last week. He attached a 115 to the existing 80. We aren't going away in the MH now until easter so cannot test till then but hopefully our heating will no longer fail.
aba
2,775
1,112
yorkshire
dec 2009
The only time you may have a problem is if one of the batteries is a lead acid and the other one a gel battery.
Although I don't quite understand why if they are both 12 volt.
17,637
43,375
gel batteries and lead acid need different charging regimes and one takes a higher initial voltage for longer then a maintenance charge to keep it topped up.
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
Please, How can you tell if one is gel or not...?
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Ordinary Batteries have a water type electrolyte (Battery Acid) easy to spill and splash
Gel Cell batteries contain a silica type gel that the battery electrolyte is suspended in, this thick wallpaper paste like material allows electrons to flow between plates but will not leak from the battery if the case is broken.
If you are going to remove a battery top up lid, Wear protective goggles + Gloves and wash any skin with large amounts of water if splashed
Batteries should:Doh: Are mostly clearly marked
G
