Wiring A Solar Panel (2 Viewers)
andy63
4,672
15,017
south shields
since 1990
hi, appreciate some advice again please.
the van has two leisure batteries, which are wired independently to a sargent ec225. ie the batteries are not connected to each other at the battery bank, but are at the sargent
I am running a supply from an mppt controller to the batteries.. should I connect the batteries together (ie parallel them at the battery bank)... my thinking is that this will avoid the charging taking place through the smaller wires connecting the batteries to the sargent
hope that's clear and appreciate any advice
ta andy
Jul 12, 2013
3,872
5,275
The City of Henlow
Adria Supreme
Since 1980
Most situations I have encountered with two leisure batteries have them connected in parallel, perhaps you are the exception but I cannot think what the benefit is.
images
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
EC225 shows two leads for batteries from the control panel
1 for leisure battery or batteries
1 for starter battery
andy63
andy63
4,672
15,017
south shields
since 1990
I was surprised myself, but my only experience is with my self build and I installed it as per your dig above, and wired the solar straight to the batteries... in this case the batteries are independently wired to the sargent but the connections are common at the sargent so they are in parallel, but the installed wiring is not what I would call heavy duty..
so if I bring the heavier wire from the solar controller to the battery locker I was thinking if I used heavier cable and paralled the batteries at source and then connect the again heavier solar control wires to the batteries that would do..
thanks for the reply
53,461
150,136
First question, why have they been wired separately, ? Is it because they are mounted a long way apart?
If they are next to each other parallel is the best option & if close together no need to fuse them separately., in the drawing above (one of Clive's I think) I would say a 25 amp fuse is a bit low, 50 would be better, but whatever fuse you fit the cable must be the same or preferably a higher rating than the fuse.
Nov 18, 2011
11,862
43,046
Planet Earth
A van
Over 25 year's
Make sur that you connect the soler last to the sytem @andy63 I have killed two controller's and fit a flush and diode
you probably all ready know that
bill
53,461
150,136
Sounds like a plan you may also need to upgrade the cable to the control panel.
andy63
andy63
4,672
15,017
south shields
since 1990
thanks andy, that is the case but each leisure battery ( 2 in this case) are wired independently to the sargent,
so was wondering how best to connect the solar charge wires to charge both batteries, and thought that if I paralled the batteries at the bank that would be the way to go..
thanks for replies
Techno
Jul 28, 2010
15,475
20,756
May 2010
thanks for replies
I would and connect the positive and negative from the regulator to different batteries
23,836
72,509
Ahhh,, the EC225 !
My pet subject !]
There are two wires going to the panel.. Only god and Sargent know why they do this.. As the wires are joined to a common point inside the panel !
So just join the solar panel to either +ve terminal and it will feed both batteries anyway !
19,368
30,325
Hi Andy
This makes it look pretty normal.
Nov 18, 2011
11,862
43,046
Planet Earth
A van
Over 25 year's
fit a solar controller for all they cost @andy63 and you will get the best Frome you solar and battery's you will get one at http://www.storelocate.co.uk/maplin/newcastle.html
I find there controllers very good and are made in Germany
bill
andy63
andy63
4,672
15,017
south shields
since 1990
Make sur that you
thanks, I have no idea why they are wired like that...its an auto trail apache 700..
the two batteries are side by side , and as said each with its own positive and negative feeding the sargent..
I want to parallel them using heavy duty wire and connect the solar charge controller to the batteries, but thought I would ask first..
ta andy
andy63
andy63
4,672
15,017
south shields
since 1990
Ahhh,, the EC225 !
My pet subject !]
thanks jaws , that appears to be the easiest option , but to my mind the wiring installed is not heavy duty enough , and I would rather run the 4mm sq solar charge wires direct to the batteries , and parallel the batteries at source,
andy63
andy63
4,672
15,017
south shields
since 1990
bill
cheers bill, ill remember that, don't want to go killing the controller,,, its not mine lol
andy63
andy63
4,672
15,017
south shields
since 1990
Hi Andy
thanks martin, had a quick look, but as no one has come up with any reason not to just parallel the batteries at source and connect the solar charge wires to the batteries as @Techno100 has described above , that's what I will do... just when its not your own van its all a bit more edgy lol
ta andy
23,836
72,509
Oh I totally agree Andy.. Direct to the battery(s) every time.
I was merely saying the wires from the battery are joined in the panel, so joining them at the batteries makes a lot of sense and is ( in my opine ) the correct thing to do
andy63
andy63
4,672
15,017
south shields
since 1990
thanks all who have replied much appreciated... its now time to actually bite the bullet and get on with some work lol..
@Techno100 , im also going to install one of those split charge relay jobbies to give the vehicle start battery a small charge , so thanks for that link in a previous thread...
ta andy
andy63
andy63
4,672
15,017
south shields
since 1990
ta jaws , really must get on with the work now...
andy
19,368
30,325
The light wires up to the panel would worry me if I was putting an inverter on, guess you would need to heavy wire between the batteries. Anyway thats another day.
23,836
72,509
The ONLY place an inverter of any size should be coupled to is direct to the batteries ( via a fuse of course ! )
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
Thanks everyone for keeping Andy right. It's our MH he's doing :) Maybe by the time I get home from work tonight it will be done with all your input.
PS I can't like the posts as all too technical for me...so Thanks.
19,368
30,325
Yes, but direct to the batteries would need an upgrade to the wiring between the batteries was my point.
23,836
72,509
Well if you are gonna couple the batteries together there is NO wire at all at the moment.. The Sargent runs two wires from the batteries to the panel.. Obviously a daft idea to start with LOL !!
