wipers (1 Viewer)
francour
94
13
Pontefract
a class
since 1990
Hi all my windscreen wipers blow a fuse after being on for about 5/10 mins but if i operate them manually with the control arm one stroke at a time the fuse does not blow any ideas Thanks Bernie:Angry:
scotjimland
2,335
10,105
A Woosh bang
I suspect the wiper arm drive linkage or gear box is stiff/tight.
The fuse is blowing because the motor is overloaded which makes it heat up and draw more current .. thereby overloading the fuse which will melt.. or blow.
A single wipe won't blow the fuse as the motor won't have heated up sufficiently ...
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
sounds like the van has been stood for long periods and wiper mechanism is partially seized, try a drop of penetrating oil on the various joints/bearings etc. should cure it.
