- Nov 1, 2023
- 103
- 2,616
- Adria
Am I right in thinking I need 2 of these monsters for the Adria's fridge/freezer vents?
Winter vent covers
Winter vent covers
Thanks for telling me that. I'll be in the van so using it.Only if you’re storing the van and not going to use the fridge. We found the fridge won’t work with the covers in place, can’t dump the heat.
I use the covers in the winter and when washing the van.Thanks for telling me that. I'll be in the van so using it.
Not disputing what you say but what is the reason for not fitting the top vent cover when running on gas ?Yes, the fridge will work better in cold weather but don't fit the top one when running on gas.
I ran the fridge all last winter with the covers on even forgot to take them off until EasterThanks for telling me that. I'll be in the van so using it.
Both my grills are much the same size with no division to reduce blank sizeNonna this is an upper fridge vent winter cover.
As you can see from the picture it doesn't blank the right hand side of the upper vent allowing the fridge to still work.
They reduce the amount of gas used.
The type of vent in your photo is not used any more.Not disputing what you say but what is the reason for not fitting the top vent cover when running on gas ?
My top vent cover still allows the fridge to work I thought.View attachment 830809
I'm glad mine is 2006 vintage.The type of vent in your photo is not used any more.
The modern way the flue just vents behind the grill so if you leave the top vent in when running on gas the cover gets very hot and the plastic goes soft.
I bought just the one for the bottom as off grid almost all the time therefore on gas, so only use the bottom one under 8 degrees.
No, mine has no flue/vent it's just large grills. I think headlight had the one you're thinking ofDoesn't that depend on the type of Vent. Ours is the same as the OP with an operate flue/vent for gas to the right of the vent. The cover does not cover this area.
I was considering that option. The bottom grill houses the pilot light.I bought just the one for the bottom as off grid almost all the time therefore on gas, so only use the bottom one under 8 degrees.
Possibly but as said, I've the same one that the OP is on about.Doesn't that depend on the type of Vent. Ours is the same as the OP with an operate flue/vent for gas to the right of the vent. The cover does not cover this area.
Exactly.I was considering that option. The bottom grill houses the pilot light.
The other plus sides to just one would be price & no need for scaffolding to get me up to the top one
My 10 year old Dometic RMS8555's manual says I should put on the vent covers. I don't know what recent fridge model manuals say.
My vent covers, "Maintain performance when temperature falls below +10C, long term periods, and to avoid snow & leaves."
I've sometimes put on the vents when washing the van to keep out the water, and lately because of the heavy rain, puddles, road spray.
I put the vents on last weekend they will still there until the end February.
It tells you to do that in the manual.I've sometimes put on the vents when washing the van
Don't leave them on when driving they tend to go AWOL, I lost one just parked on the drive in strong winds. Don't normally park that way round on the drive normally the fridge is on the leeward side, if I do park the other way round I don't fit them.I put my vent covers on for my trip last weekend as where I was going was forecast 5c overnight and very strong winds.
I will leave them on till March, wash the van then take them off.
I must read that at some stageIt tells you to do that in the manual.
When I am finished using my MH, I unclip the fronts wrap in cling film and refitAm I right in thinking I need 2 of these monsters for the Adria's fridge/freezer vents?
Winter vent covers
