Who makes the habitation doors for Frankia? (1 Viewer)
H
Hagstrom
Hi,
My habitation door inside handle cover has just broken into two pieces. (Hopefully, there's a photo of it above/below/attached.)
It's a small plastic decor trim part which would cost two hundred guineas through the agent so looking for the identity of the hab door maker for Frankia. I could try going direct to the maker first. Any clues anyone?
canopus
6,139
10,257
rural Lincolnshire
Carado CV640 Pro
Since 2010
Minxy
32,651
66,551
E Yorks
Carthago Compactline
Am I right in assuming this is just a decorative cover and doesn't need to move? If so I'd carefully trim the edges if necessary and stick it together with some good glue, with some support strips behind the cracked parts (trimmed old credit cards work well), one solidly stuck then fill any gaps, sand and spray black ... a lot cheaper!
H
Hagstrom
Thanks MinxyGirl, that's exactly what I've done, using some German double side tape. It's been a good fix but I'd like to replace the part if possible.
Jul 24, 2009
4,330
104,502
South Yorkshire
Since 1999
I tried to deal directly with Frankia but they won't play ball. They'll refer you back to the UK dealer.
Apr 23, 2010
945
1,777
Isle Of Man
4 years
Hi @Hagstrom
This is a German manufacturer,but if you follow this link,sorry google search it will bring you to the U.K. agent who should be able to get you the part.
Happich UK.
Hope that helps.
Steve.
Xabia
1,186
821
Rural Nottinghamshire and Spain
Since 1996
Hi,
Thank you so much for posting this thread. Would you believe that exactly the same part is on the driver's door of my Hymer! Thanks also to the chap who gave the heads up of where to source a replacement
