Who checks safety of adaptions to motor-homes? (1 Viewer)
deegee
15
A forest in India
Looking (prev self-build)
10 years full timing
I would like to fit some fold-up extra seat-belted seating to a motorhome. Can someone tell me who is responsible for approving such adaptions as safe? Is it the DVLA? When I built my own van in 1993, you had to have a private contractor inspect it and issue a certificate which you then presented to the DVLA who amended the V5.
Squire
324
60
Amended the V5?
What has the V5 registration dcument to do with seat belts?
The V5 for my van doesn't mention seat belts, neither type of nor number of them.
And a new van doesn't have any certification regarding seat belts to pass on to the DVLA on first registration, either.
As far as I know it's a type-approval matter. Perhaps the Caravan Council can help with your query.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Hi deegee
You wont get an official certificate of approval anywhere.
I am not aware of any, ever being given to self builds by anyone
Your best source of advise would come from a kit car manf or motor sport constructor
An MoT station has no criteria to test to other than what is already fitted and at best is a simple visual inspection, So long as type aproved seat belts are used, and mountings well thought out and secure I see no problem
This week we have stripped out and re built the side of a motorhome with damp problems, and rotted timber framing
1.3/4" timber used throughout, Including the seatbelt mounting point on the B pillar
We had no alternative but to replace like for like, we however used oak as a replacement timber, The original construction has in the past complied with stringent German TUV regulations, Go figure
Geo
43,331
49,467
in my view you would ultimately be responsible for the fitment if you fitted it.
if a belt mounting failed resulting in you being sue'd you would be holding the sh:tty end of the stick in court.
artona
1,511
817
self build
40 yrs and still not got a release date
Hi deegee
I have just built my own camper. I have seen mentions of engineers reports etc prior to havign the V5 changed but I didn't, I just took a few photographs, sent it in and the amended V5 came back.
I did take it upon myself to get the gas and electrical systems checked after I had them fitted just to be sure. I think if I fitted seatbelts I would try to imagine what ways a passenger might be thrown in the event of an accident and give them a good tug to test
stew
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
Hi Deegee I also built my own and have also retro fitted seat-belts to some forward facing seats in my van before my present one.All you have to do is satisfy yourself that the anchor points are strong enough - mine was bolted to the floor and I made a 1 ins box section into the seat back for the upper mounts also bolted to the floor and fixed to the van loo wall for good measure :thumb: As to sending photos to the DVLA -nope- the only time they require proof is when you register the van from / to motor caravan,for that they require front / rear photos showing number plate and one interior :thumb: After that they may request you to take it to your local VOSA for a inspection
terry
D
deegee
15
A forest in India
Thank you for your responses. The advice I've received when asking ranges from "don't do it", "impossible", "forget even trying", to "you only have to be sure they're strong enough". Whilst I take the warnings of court consequences were there to be an accident, my view is that we should do all things professionally and properly and not avoid risk because of fear. Life would be very dull.
Have a look at this video. Half way through you can see the Hymer fold away seats with belts incorporated. Presumably these could be fitted to an existing van if securely bolted to the chassis.
Link Removed
I am, though, confused about the legality of fitting extra seats like this.
artona
1,511
817
self build
Link Removed
well of course you are right Deegee. So fit your seatbelts, strap a dummy in, fit a high speed camera so you can check afterwards and then find a disused airfield with a 7 foot thick concrete wall and crash test your motorhome at 70mph :Doh::Doh::Doh:
Only joking of course but I am not sure how you can fully check things other than thinking it through and fitting as described in earlier posts on this thread
