Which way is your MH door hinged? (1 Viewer)
Jun 18, 2008
1,588
2,281
Lancaster
None
Since June 2008
We popped into Marquis last week to ask about getting a Fiamma handle fitted. We were told that the door on our Majestic 165 is very unusual in that it is hinged on the right (opens to the rear of the vehicle).
So, quick survey thing - if you have a RHD van with the habitation door on the passenger side, which way is your door hinged?
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
The hinges should always be at the front of the van
If it is not fastened or closed then the wind force will hold it shut or close it
If the other way around it will be held open or flap outwards
Techno
Jul 28, 2010
15,475
20,756
May 2010
Having said that I can see two caravans from where I'm sitting that contradict that. Common sense and safety should prevail
scotjimland
2,335
10,104
A Woosh bang
I've seen them hinged both ways, as said you would think it was common sense to have them hinged on the front .. but is it such an issue ?
Let's say you forget to close and drive off .. hinged at the rear and it will simply stay open.. you will soon notice and stop... hinged on the front and it might close .. maybe not if it's on a latch.. or it may slam shut and break the catch ?
I don't particularly see it as a safety issue.. nor do some motor manufacturers..
Broken Link Removed
longdog
Banned
Apr 16, 2013
255
287
Totally agree that this is the way it should be :thumb:
And by the way, the Ace has the habitation door hinged correctly too
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
if you have a lhd the hab door will be hinged on the right:Doh:
I never believe much the dealers tell me
scotjimland
2,335
10,104
A Woosh bang
There is probably a reason to hang to the rear..
for example.. some vans have a fridge right by the door.. if it opened across the vents that would be poor design.. or perhaps a cassette toilet hatch.. not a real issue but not convenient.
AuldCodger
284
128
Memory
Certain that at one time there was a ruling that all doors must be hinged on the leading edge.
Off for a little chat with Mr Google to see how good the memory is.
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
We have a CI David Bowie limited edition, so the door swings both ways.
Jan 22, 2013
1,254
60,336
London SE
A class Adria vision I707
since 1971
Broken Link Removed
The car in question and all the latest cars with front opening rear doors have a electronic interlock to stop the doors opening when in motion and or stopping the car starting if the doors are not shut, so not quite the same as the habitation door on a motorhome/ caravan,
scotjimland
2,335
10,104
A Woosh bang
Do people generally sit by the hab door in in motorhome .. or indeed a caravan .. that would be illegal on the move.
the only type I can think of is a PVC where there is sometimes a seat by the sliding door.. and that opens backwards.. no interlock, no start inhibit.. in fact white van man can be seen driving with it open..
the main point I made was I didn't see it as a safety issue.. nor obviously do the manufacturers ..
anyway.. I fail to see why you thought it necessary to point that out..
1,254
60,336
London SE
since 1971
Just pointing out that the current rear hinged doors on the latest vehicle are deemed a safety issue! Otherwise the manufactures wouldn't have bothered with the electronics to stop them being used when in motion,
my motorhome does have a seat next to the habitation door, but my door is front hinged so isn't a factor,
I consider these forums to be a good way of exchanging information to everybody benefit and not to get into a P---ing contest:Doh:
Techno
Jul 28, 2010
15,475
20,756
May 2010
It's obvious why it was pointed out :roflmto:
You chose to use it in support of your point of view and it is shown to be a bad example
scotjimland
2,335
10,104
A Woosh bang
[ame="https://www.youtube.com/watch?v=GQ5ICXMC4xY"]https://www.youtube.com/watch?v=GQ5ICXMC4xY[/ame]
Linda and Steph
Jun 18, 2008
1,588
2,281
Lancaster
None
Since June 2008
I've just checked the specs of the current Majestic range,
Rear hinges - 125, 155, 165, 175
Front hinges - 105, 115, 140, 145, 180, 195
Our 2010 Autoquest 180 also had rear hinges.
I always double-check windows, doors and lockers before driving so I'm not too worried about the safety issues.
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
Do you mean the imaginary safety issues
oldun
747
162
St Neots
VW Campervan
Since 2001
Mine slides.
peter marshall
2,466
1,704
Cleveleys,Lancashire
Low Line
9 Years
If the hinges are to the rear they were always known as " suicide doors " for obvious reasons.
We used to have Vintage cars for an Hobby, quite agree if you grabbed at a rear door opening when traveling the wind could drag you out thats how they got their name, the only one we had with rear hinged doors was a Hillman 14 1929 reg so safty reg's and seat belts were not invented then. Pete
