Which Solar Panel Do I Need? (1 Viewer)
yorkist
64
31
Altea-Benidorm
busy researching now
sadly none yet
Having just bought a Bessacarr e495 I want a solar panel fitted asap. I haven't got the time to think about doing it myself within the next few weeks so I'm going to ask some technicians near Sheffield. But which panel is right? And how much do they cost? 90w or 120w seem to be common. I imagine it's a case of the bigger the better although weight is an issue. There's only one leisure battery so I'm guessing I ought to but another. Any advice appreciated.
Nov 30, 2009
6,547
148,996
Pickering
PVC the PUG
Ralph has fitted victron blue solar on Pug. 2x80 watt controlled by a victron 3 stage charger. If that helps at all. It's all gobldeegook to me.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
2 x 120 amp/hr batteries and a pair of 80W panels should see you right.
Dec 12, 2010
5,413
21,580
Cumbria
since 2011
If weight is an issue, the flexible ones are a lot lighter. They're not as efficient apparently but watt for watt are a fraction of the weight. I've just fitted a 150w unit that weighed 2.5kg as opposed to a traditional unit that weighs around 9kg and no extra brackets to buy/fit.
I have 2 x 110a/h batteries and led's and the setup seems to be working well so far.
Baggers53
187
221
Stafford
We have a e425, there is only 1 battery and no room for another one.
So I bought a new 110a battery and fitted a 100w solar panel, and it all
works a treat.
musson
487
165
grantham
low profile
since Jan 2014
Hi I leave my MH about 9 miles from home I have two 95amp leisure batteries and the starter battery i use a 100watt panel and it work perfect,I have used it for rallies over 4 days and again works.
