Which Sealant (1 Viewer)
Pat4Neil
1,247
494
Essex
Mercedes
7 years
I recently applied some General purpose silicone mastic around my shower tray but it really didn't adhere to the shower tray very well and only lasted a few weeks before it started to come off.
The shower tray is a smooth blue plastic molding, I am not sure what type of plastic it is but it has that waxy feel to it, not unlike a kitchen chopping board.
Can anyone point me in the right direction as to the best type of sealant to use .
Many thanks
Neil
Terry
11,932
9,084
Lincolnshire
Can't remember ;)
HI TRY Link Removed
or there STICKS LIKE range -comes in white or clr
terry
Edit if you use silicon you must use a low modulus one ---not high modulus
froghopper
412
181
winchester
c class
before they were invented
Silicon
Hi, can't remember name but sold in aquarium and tropical fish places. Yellow tubs. £12 but can be applied under water. Did a split in ours. Perfect....just be careful black and clear are in same colour tubes
Jan 8, 2013
8,490
11,527
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Many thanks
Neil
After trying dozens of silicon sealants over the years, the only one I buy now is Dow Corning - completely reliable.
Sikaflex is also highly recommended for gluing and sealing any thing.
Alex
gpz
May 24, 2012
255
34
north yorkshire
converted movano
newbie
sealer
dow corning is the way to go most good plumbers merchants should sell it , make sure all the old sealer is cleaned off and it must be 100% dry or it will not stick and leave for at least 24 hrs befor useing it
Terry
11,932
9,084
Lincolnshire
Can't remember ;)
Alex
As I said in my earlier post, if you want to use DOW CONING make sure it is LOW modulus :thumb:if you use a high mod one it will NOT stick to plastics and peels off like a elastic band which is what OP says happened :Eeek:::bigsmile:
Terry
mentaliss
654
306
Lancing
C class
Many thanks
Neil
best by far (but difficult to find) Tech 7 most advanced M7 POLYMER adhesive/silcone... general purpose silicone will not take the weight movement on the tray, all M7 Polymers will dry flexible and retain their adhesive power.
Pat4Neil
Pat4Neil
1,247
494
Essex
Mercedes
7 years
Thanks very much for the advice folks, will see if I can find some now.
Neil
