There are supposedly 2 different kinds of gas for the air conditioning! How do I know which gas is in my 2013 lhd Citroen jumper 2.2 diesel a/c?
it’s the “twice as expensive stuff” R-134a
Bugger
They probably didn't turn the fan on as citrëon, reanault & peugeot still retained the stupid system whereby the ac won't work if the fan isn't on whereas other manufacturers made turning on the ac start the fan even if it was in the "off" positionAnyway took my van to kwikfit (it’s just round the corner) to get my a/c re gassed when I went to pick it up (after 2 1/2 hours) they said no charge as they couldn’t get the ac to work!
Drove it home, put the ac on and it’s blowing ice cold air!!????
They did say there was no gas in it and it took the full amount to re gas it!!!!!
Perplexed
The fact there was no gas in it at all indicates you have a leak. Keep any eye open for green die that they put in the system.Anyway took my van to kwikfit (it’s just round the corner) to get my a/c re gassed when I went to pick it up (after 2 1/2 hours) they said no charge as they couldn’t get the ac to work!
Perplexed
I had a similar issue with mine. We were away in the hot June weather A/C not working. I had a regas and they told me they couldn't get it to work and thought it was potentially a knackered compressor because it was clicking on and off for no apparent reason. I booked it in for further investigation a couple of weeks later and on the way there I noticed cold air coming out. They checked it over and it was fine. No idea why but I believe there is some lubricant included with the gas when they recharge the system so maybe it took a while to take effect? Who knows!!Anyway took my van to kwikfit (it’s just round the corner) to get my a/c re gassed when I went to pick it up (after 2 1/2 hours) they said no charge as they couldn’t get the ac to work!
Perplexed
