Which adhesive do I use?
Discussion in 'Tech/Mech General' started by goneoff, Nov 24, 2015.
  1. goneoff
    goneoff Funster
    Aug 19, 2009
    130
    18
    Leicestershire
    I unfortunately reversed my Rapido 9066 into a tree and put a 2” crack in the rear white decorative plastic shroud which covers the corner of the motorhome. Rather than having it repaired I have decided to adhere a reflector over it which I don’t think will look amiss, in fact two reflectors one on the other side to mirror the other. The question I need to ask the more experienced DIY Funsters is which is the best white flexible adhesive to use for the job. Thanks in advance.
  2. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,063
    1,196
    Dronfield - Derbyshire
    I've used Airfix type glue and stuck a patch at the back. The worst problem is finding the same kind of plastic - that also melts with that glue.
    The only thing I've found up to now is an old piece of Swish curtain track - it seems to be the same kind of plastic and melts together a treat.
  3. Allanm
    Allanm Funster
    Jun 30, 2013
    3,135
    4,279
    Cotes d'armor, France
    Sikaflex seems to stick anything to anything else. Might be your best bet
  4. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,084
    5,369
    Guisborough
    If you are going to cover it up anyway with a reflector or two, you could try repairing it with a soldering iron, just run the clean hot tip into the crack and smear any molten plastic over the crack, you could even shave a bit of plastic from an edge somewhere out of sight and use this as a filler. You never know when its all cleaned up and polished you might not even need the reflectors.
    Oh, answer to your question Sikaflex would be fine but lots of reflectors come with double sided on the back anyway.
    Martin
  5. goneoff
    goneoff Funster
    Aug 19, 2009
    130
    18
    Leicestershire
    Thanks Martin
    In truth if I had it repaired I would have it professional done, although small it would need both plastic welding and filling. I will ultimately have it done I am sure but will settle for a reflector for now.
    • Like Like x 1
  6. goneoff
    goneoff Funster
    Aug 19, 2009
    130
    18
    Leicestershire
    Thanks but which Sikaflex aren't there various types?
  7. goneoff
    goneoff Funster
    Aug 19, 2009
    130
    18
    Leicestershire
    Thank you, I don't think it would work on this small damage but what you suggest is good for the future
  8. SomeoneElse
    SomeoneElse Funster
    Apr 22, 2013
    576
    378
    Cotswolds
    Email technical@uk.sika.com giving them the two materials you wish to bond together and they will send you a recommendation.
    I did for my solar panels and the reply came back in minutes.
    • Like Like x 1
  9. goneoff
    goneoff Funster
    Aug 19, 2009
    130
    18
    Leicestershire
    Cheers I have just emailed them.
  10. mentaliss
    mentaliss
    Nov 2, 2012
    657
    307
    Lancing
    I did a similar thing to my rear lighting shroud, took it off , de greased it, cut a strip of fibreglass, bonded it to the back of the crack (strengthening it) plastic filler to the crack, flat down with 200 paper, aerosol spray to colour that was two years ago..job done.....£150 if a bodyshop had done it
  11. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,113
    3,516
    walthamstow east london
    use clear stixal from tool station every bit as good as sika under half the price available in white as well
