Where's My Battery? And A General Leisure Battery Question. (1 Viewer)
TheWM
445
450
London
Rapido 9010df
Newbie, but over 10 years in a campervan
Along the list of absolute stupid questions - here goes. I thought my battery would be under the drivers seat. I can't actually see it so is it a seat out job? I have taken a pic there appears (to my untrained eye) to be some kind of earthing strap popping out which makes me think it may be hidden away.
The reason I ask is twofold. I want to know whether my solar panel has some kind of battery master that tops up the starter battery when the leisure battery is topped up. And where to jump it if needed!
My panel reads 13.0v on the leisure but is drawing 2 amps (with all off is this being drawn from the panel?) and 11.8v for the main battery.
I've attached pics of where I think the main is and the leisure batteries. Anyone got any comments about the leisure batteries in terms of their spec and longevity?
jonandshell
5,476
8,299
Not got one!
Your Rapido will have a CBE electrical system. This will look after your starter battery. Once the leisure batteries are fully charged, the starter battery gets charge too.
The batteries are Banner Gels by the look of it. Good batteries but you need to ensure your mains charger is set for Gel batteries.
There is a small dip switch inside the charger which you need to check. It is labelled gel or PB, meaning lead acid.
Ensure you are unplugged from EHU before removing the front of your charger to check though!
Reactions: f6c
TheWM
TheWM
445
450
London
Rapido 9010df
Thanks. Where is said mains charger?
19,420
30,540
Hi @jonandshell what makes you say that these are GEL batteries, Banner 59533 is a starting bull wet battery according to Mr Google.
Also not sure if all CBE systems have the facility to look after the engine battery I know ours does but I thought that part of the system was an option.
makems
3,440
27,728
Ingleby Barwick,,Teesside
Sadly had to give up
Do you have the original Rapido handbook?
It shows where the CBE box will be - it can be in a different location depending on which model you have. On the 983M we used to have it was inside the rear n/s garage door on the bulkhead.
TheWM
TheWM
445
450
London
Rapido 9010df
Thanks guys. My manual is in German and not very handy when meine deutsche ist nicht so gut! I would be well happy if they were gel batteries! Ps am I right in thinking that the starter battery is under the drivers seat (lhd)?
43,365
49,711
At 11.8v your starter battery it is well discharged and probably needs replacing....either not accepting a charge or not holding one.
At rest (off charge for an hour and not under load) it should read at least 12.6v.
At 13v your leisure batteries are getting a charge from your solar panel which will be where the 2 amps reading is coming from....2 amps going into the batteries.
TheWM
TheWM
445
450
London
Rapido 9010df
Thanks.
Looks like I may need new batteries all round as when I sat in it on Sat with a bit of music and friends with lights on, it dipped down to around 11(ish)v. I assumed that the batteries probably needs replacing as they are probably 6 years old.
So - how do I get to the starter battery on a Rapido A Class, as this seems to be the main problem currently!
4,094
5,915
SW Scotland
LP Coachbuilt
What make is the chassis and what year and engine configuration is it and someone will know.
Mr B
992
1,894
Yorkshire
Rapido 7065ff Design Edit
Since 2015.......
Your battery is between/front of the seats. Rubberised panel lifts out and it's there.
Your leisure battery's should be under one of the lounge seats just behind the drivers seat.
If you come across an English version for the manual, let me know. Mines in French. I'll send you the link for the Ducato user manual if you want. :)
Oh, my charger, control panel etc is on the left, in the rear mini garage.
TheWM
TheWM
445
450
London
Rapido 9010df
Just emailed you. I should be able to get a download and will send you a link :)
Mr B
992
1,894
Yorkshire
Since 2015.......
Just seen your photo. Lift your carpet up in the cab area and you will see the inspection panel for the battery
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Some CBE panels only charge the engine battery when on hook up including mine (DS520RA)
TheWM
TheWM
445
450
London
Rapido 9010df
Thanks all - I found it! See pic.
Does look like 'more' wires than I'd expect to see on a starter battery. I'm guessing that it may have additional charging?
