What Size Wheels For 4t? ? (1 Viewer)
May 23, 2008
2,481
3,483
Near Durham City
Carthago
Since 1984
Over the years I have always been advised that any weight upgrade over 3.5t should have 16"wheels as standard. I've just been talking to a very very unhappy new timer in France who has just purchased a hymer c class. It's brand new and the dealer made a total mess of his original order even down to the tonnage. He has 15"wheels and the dealer upgraded the vehicle through SVTech to 4t. Is this now okay with this size wheel .
Any help for this future funster please.
Mar 26, 2009
8,163
11,221
Yr Wyddgrug
Hymer B678DL
Since 2009
My Autocruise Starspirit has 15" wheels and has been upgraded to 3.7 ton by SVtech. The only modification it had prior to the upgrade was 'Air assisted suspension'. (Not sure if this information helps you any.)
SMB
Apr 26, 2013
1,230
1,347
Spain
Coachbuild
Fulltiming since February 2013
I think the upgrade by SVTech also takes the speed rating of the tyre into consideration as well. Im going to the weighbridge when I get back to the UK in a few days (if the French let me) to see if I need the upgrade. My van is currently rated at 4005kgs btw and has 16" 225/75 R16's fitted.
edgy
389
475
bolton lancs
lo line
"I,m a newbie
It is down to the tyre rating and not the size. He will be ok on 15" rims as long as the tyre rating is up to spec. I have a Merc and that can go up to 4 ton with the tyres on it on 15" rims . This was told to me by SV tech
Jean-luc
104
69
Rapido 963F
Hymer S700 1992 4600kg has 14 inch wheels.
Not quite the same. The S700 is built on a 410 D chassis with a twin wheel rear axle.
wizza
175
117
Essex
low line
8 years
Upgraded to4.1T from 3.5T Maxi chassis 16 inch wheels, had to fit air assist to rear, tyres 215/75/16/116/114
seabreezesports
45
81
Devon
a class
I,m a newbie
Read your tyres . There is a load rating on them with the maximum pressure. Be aware this is the maximum and the manufacturers don't expect their tyres to be at that weight all their lives . I would knock 10% off for motorhomes Maybe more if you tend to drive at motorway speeds.
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
Possl 636 FR panel van
1994 and beyond...
Problem with paper upgrade is axle capacity stays the same if not on maxi chassis which he presumably thought he was getting?. There lies the compromise, cock up, whatever you want to call it
He should have rejected it, insisted on getting what he ordered....
